Ir para o conteúdo principal
O Sony Xperia Z4 (conhecido como Sony Xperia Z3+ na Europa). Smartphone com display de 5,20 polegadas e 1080x1920, equipado com processador de 1,5 GHz, 3 GB de RAM e câmera traseira de 20,7 megapixels. Foi lançado em 2014.
Display is not working after Dropping
Hi There!!
My phone has been dropped from my hand. Since then the display went completely black. When I tried to turn on, it makes the vibration as normal Sony phones does. But after couple of seconds just the notification LED blinks RED and the motherboard gets overheated. Sent to a local repair shop, but they couldn't fix it. They put a new display , however still does the same. What is the problem and how it could be fixed?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
I could be wrong on this since I'm always learning but it is possible that a component on the board has been damaged. Voltage is sometimes sensitive and with drops, parts could bad. It sounds like a lcd problem since there is no image but if it has been replaced, then possibly the back light or a component for the lcd on the board could be damaged.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
riaj_shuvo será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 16
Ao todo: 487
