Ir para o conteúdo principal
Um monitor de bebê fabricado pela Infant Optics, Inc. O DXR-8 possui uma tela de 3,5", Sensor de temperatura, visão noturna e um sistema de lente intercambiável.
Display screen will only display vertical lines.
I have the Infant Optics DXR-8 and recently the display screen has gone to only showing vertical lines. You can tell the monitor is switching between the 2 cameras we have because the lines will change colors, but nothing is visible. Is there a way to fix the display screen?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
did anyone drop the LCD device or put too much pressure on it (sat on it maybe)?
do you see any discoloration on the edge of the LCD?
My bet is the LCD have been damaged have it brought to the service center so they can confirm the issue specially if it's under warranty. If not you may wanna try opening it and see if it could be a connection issue.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Annie Brown será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 22
Ao todo: 3,374
