Ir para o conteúdo principal
A impressora multifuncional a jato de tinta HP Officejet 6600 é um dispositivo 4 em 1 que pode imprimir, digitalizar, copiar e enviar fax.
Ink system failure message
The message says the printhead appears to be missing, not detected, or incorrectly installed.
I uave done everything HP told me to do and I still have this error. It looks like the black ink spilled inside the printer. Xan I have this repaired or should I just get a new printer. I have already tried to clean all of the ink out but I can't reach inside to get it all out.
Esta é uma boa pergunta?
Pontuação 1
2 comentários
I tried one thing once. And it worked then it messed up again. Now it says print head appears to be missing,not detected, or incorrect.y in
Stalled
por
It worked for me on the, ow it doesn’t work
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Printhead issues are very common in this line of printer. I believe you can replace this yourself. You can simply use a cheap refurbished from Ebay. ($29 ish)
Here is a printhead replacement video for a 6700
https://www.youtube.com/watch?v=jSPXV3an...
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Sam Bird será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 17
Ao todo: 2,698
