Ir para o conteúdo principal
Um sucessor do smartphone LG V10, semelhante ao LG G5, lançado em 29 de setembro de 2016. O LG V20 pode ser identificado pelos números de modelo F800, H910, H918, H990 DS Dual, H990N Dual, H990T, LS997, US996 e VS995. Está disponível nas cores titânio, rosa ou prata com 32/64 GB de armazenamento.
USB C port replacement
What is involved in replacing a damaged UCB-C port on the LG V20? Actually, I could ask a similar question for my iPhone 6S Lightning port. It's been pointed out that one advantage to "wireless" charging is the reduction of wear on power sockets. With daily use, that would be around 700 plug ins over a two year period, so wonder if this comes up often as an issue, and if so, how to replace a damaged power port.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
heres a video of the disassembly https://www.youtube.com/watch?v=5yC0ROV3.... to do the replacement you will need a hot air station, a soldering iron, flux and some leaded solder
Esta resposta foi útil?
Pontuação 2
1 comentário:
Thanks. I'll review the teardown you supplied.
por Compartilhar
It can in fact be removed and replaced, but you definitely need a hot air rework station, in my opinion. I did find a YouTube video by a very talented person who was able to do it without a hot air rework station. The video is very well done, and I only wish I had his talent and steady hands.
https://www.youtube.com/watch?v=WgXMjRAU...
I took an old broken LG V20 logic board and was successfully able to remove the connector without damaging the board using my rework station. However, due to the heat, the connector that was removed did not survive. The board was fine, and no other SMD parts were moved or appeared damaged. I know that you can purchase the connector itself on Ebay. Be aware that it has both surface mount pins and 6 thru hole pins as well.
Pontuação 2
Adicionar a sua resposta
William Vaughan será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 13
Ao todo: 5,605
