Ir para o conteúdo principal
At my whits end!
I have a Toshiba Satellite L75 with a broken monitor so I hooked up a monitor via hdmi. I was having a bunch of problems running slow and there was to much crap on this computer so I decided to do a reset on it to factory while leaving my files. Everything was fine while I could see what was going on and then it went into restart and I lost the monitor. Now I have a computer that won’t do anything but light up. I disconnected the laptop monitor hoping that would make the computer reconsider the outside monitor but it didn’t I tried the fn + f4 still nothing. Please help?.....
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
So what you may have done is reset the OS and graphics drivers back to an earlier date when the drivers didn't naively pick up a second screen.
Perhaps if you connect the LT to a monitor via the VGA, it might pick up the monitor, typically VGA has builtin basic windows drivers, where HDMI usually needs drivers.
Let me know if that helps.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Larry Johnson será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Ao todo: 446
