Ir para o conteúdo principal
Released in 2008, the Sony Walkman NWZ-E436F is a portable media player with a 2-inch screen. It can play audio and video and has a built-in FM radio tuner.
Is it possible to get data off the chipset?
A client of mine is asking if there is anyway he can retrieve the files from his broken walkman I've already ordered a new cord to determine if that's the issue. But if that doesn't work is there a way to pull the data straight from the memory?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
@shanemkelley no there is not unless you have a NAND reader and other expensive data recovery equipment. Definitely not for any DIY'er or small shop. The only way to get the data off is if you can get it to turn on.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Shane Kelley será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 173
