Ir para o conteúdo principal
Um videogame de tv fabricado pela Sony Computer Entertainment, também conhecido como PS4. Primeiramente anunciado em 20 de fevereiro de 2013 e lançado em 15 de novembro de 2013.
1697 Perguntas Visualizar todos
Please help! I messed up
I opened up my ps4 to replace my HDMI port but while taking the power supply off the battery connectors ripped off and now i have no clue what to do specially after the HDMI replacement was also a failure.Also I dont have the money to fix this.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
You just have to solder the connections back on. Unfortunately you'll either have to learn how to micro solder, find someone who will do it for free or pay to have it fixed. I wish there was some way to fix it remotely, but there isn't. Sorry for the bad news.
Esta resposta foi útil?
Pontuação 2
@ragingwolftv you are runnig into some major issue here. First you want to let us see the damage to your PS4. Use this guide Adicionar imagens a uma pergunta já existente to do so. It might be possible to repalce the traces on your board, or is the solder pads are actually still good, to resolder this. Again, we have to see it first.
2nd problem you are having is "I dont have the money to fix this" that means you will have to learn how to do some pretty good soldering while you are trying to fix the damage. I'd suggest you contact the console guru @tronicsfix and have him guide you with this.
Pontuação 1
Adicionar a sua resposta
Joel será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 146
