Ir para o conteúdo principal
O HP Pavilion g6-1b79dx é um laptop de 15,6” com acabamento em estanho lançado em 2011. Ele possui uma webcam integrada e um processador Intel Core i3.
Unable to delete 0 byte file.
I was playing with batch files and accidentaly created a 0 byte, no extention file.
Imagem
I googled the problem and I found out that closing explorer.exe and deleting the file via command would help. Tried that. It didn't help. Any software that could do it? Any other suggestions?
Thanks for your help in advance :)
Esta é uma boa pergunta?
Pontuação 0
7 comentários
Honestly, if its doing no harm to the laptop, you should probably just leave it.
por
It's taking up space on my desktop. I need that space :(
por
I would suggest using an administrative login to examine the file permissions. You need to open up the permissions and try the delete again afterwards. Windows file system permissions can make you want to resort to violence at times. Use of cygwin can help sometimes when all else fails.
por
If its just taking up space on the desktop, you can set the file to be hidden so you cannot see it unless you have view hidden files enabled. also what is this File Unlocker thing mentioned in the file description?
por
@professorc I doubt changing the permissions would do anything. Cygwin on the other hand might. I'll try that. Thanx for your help.
por
Exibir mais 2 comentários
Adicionar um comentário
2 respostas
Solução escolhida
As I stated earlier.... Windows file system permissions can make you want to resort to violence at times. Use of cygwin can help sometimes when all else fails.
Esta resposta foi útil?
Pontuação 1
Pergunta mais útil
Create a new profile in Windows with admin privileges.
Log out of the current profile.
Log into the new one.
Use explorer to go to your other profiles desktop location.
Manually delete that file.
Pontuação 1
2 comentários:
Thanks for your answer but explorer.exe simply does not see the file as... a file. Creating a new account would probably do thesame as killing explorer.exe and deleting the file via cmd which did not help as I said in the question. Thanks anyway.
por
From the new profile open a new profile, open a command prompt with administrator privileages, and then use command prompt to navigate to where the 9 file is. Then "rmdir /s <file name> or del <file name>.
por
Adicionar a sua resposta
SLimy será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 19
Ao todo: 918
