Ir para o conteúdo principal
The Nintendo GameCube Controller DOL-003. Released November 2001, compatible with Nintendo GameCube and the Nintendo Wii, and to a more limited extent, the Nintendo Wii U and Nintendo Switch. Repair for this device is straightforward and requires only common tools.
Where do I find the positive and negative power sources on the board?
I am looking for power sources on the GameCube Controller motherboard. I need a positive and negative so I can connect some joystick LED's but I don't know where they are. Could anyone help me? I have two wires that I need to solder I just don't know where I need to solder them. Any help is appreciated.
Here's an image of LED Joysticks on PS4 controllers. It's the same concept but I want to do this with GameCube Controllers.
https://imgur.com/Kjmelo1 - Controller
https://imgur.com/ojsBInk - LED
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
@zad what you need to do is to post an image of your circuit board so we can point out where to solder to. It is one thing to look at what you want to do but you need to help us to help you. Use this guide Adicionar imagens a uma pergunta já existente to do so.
Use your multimeter and trace where pin 1 terminates on the board. Pin 1 carries 5V and pins 2 and 5 are ground.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Zad será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 12
Ao todo: 1,044
