Ir para o conteúdo principal
HD action camera with touchscreen LCD, released October 5, 2014.
camera not charging from usb port
usb port not working
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
simon gonzales check to see if there is debris in it. Also check for broken pins corrosion etc. If none of that applies you have to take it apart and see what is going on with it. Check to ensure it is still fully connected. Use these guides GoPro Hero4 Silver to work on it. Oh and you do want to get a new battery as well. If your battery is depleted it will no longer charge.
Esta resposta foi útil?
Pontuação 1
Not charging from port
Pontuação 0
Adicionar a sua resposta
simon gonzales será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 1,160
