Ir para o conteúdo principal
O DJI Phantom 3 Advanced é um sistema de voo controlado remotamente, lançado em abril de 2015. Número do modelo: WS22
My dji phantom fall
hi, when my phantom 3 standard fall , camera wont to be stable and its keep shaking ?
I checked the flat vision and gimbals cable there is nothing wrong with it ?
what can I do to get it fix
thank you
Esta é uma boa pergunta?
Pontuação 2
1 comentário
Hello. If your drone has crashed and the camera is failing to synchronize or hold a steady position, the issue often stems from the log files on the SD card. Since the drone writes data to the card during and after the crash, these files should be deleted before you restart the drone; this allows the GPS/geodata log files to be recorded fresh and error-free. Try restarting the drone after deleting the log files from the SD card—that is how I got mine working again without errors following a crash.
por Compartilhar
Adicionar um comentário
2 respostas
Pergunta mais útil
i had this same thing happen to my phantom 4 i had to replace the entire camera assembly.
they told me it had to do with the motor not being about to stabilize anymore.
Esta resposta foi útil?
Pontuação 1
3 comentários:
what did you do to resolve this? i have the same problem.
my phantom 3 advanced crashed and after that the camera or gimball keeps on tumbling . and what could be the cost to let it repair?
por Compartilhar
@sjoemie if you goto the DJI site they sell replacement gimbals for most models
por Compartilhar
por Compartilhar
Hello,
Pontuação 0
Adicionar a sua resposta
Iraqi for ever será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 22
Ao todo: 545
