Ir para o conteúdo principal
30 amp fusible link blown
The fuse box under the hood has a 30 amp fusible link that is blown. I replaced it and blew again, and was told by friend to replace the fuel pump. Engine turned and problem seemed to be solved but happened again when I closed the hood. Found the right turn signal had a blown wire just behind the light. Since the fuse has not blown but I am waiting for it to happen again.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
@estgarcia85 since it is working for now you may just have resolved that issue. If it happens again, you'll have to check again. Problems like this are really hard to resolve since there is always more than one possibility. Post a picture of this "fuse box under the hood has a 30 amp fusible link" with your question so that we can check the wiring diagram. Use this guide to post images with your question Adicionar imagens a uma pergunta já existente
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Esteban Garcia será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 12
Duração total: 634
