Ir para o conteúdo principal
Released by Nikon in March 2015. Part of Nikon's Coolpix series.
20 Perguntas Visualizar todos
My camera screen is black.
Hi Adam, im hoping you might be able to shed some light on this subject. My camera screen is black. Although the camera turns on, flash works, the shutter clicks as though a picture is being taken, screen is black and when you click it it appears to take a black picture. This camera is fairly new, probably not within wauranty though but i can see only 107 pictures taken, probably a few more than that, that we deleted but - light use. Does the LCD screen commonly burn out in this model camera to your knowledge. Thank you for your help. Melinda Rhodes
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
Melinda Rhodes you want to try and download those pictures to a computer and see if they are all black. If so, it is not necessarily your LCD. If that would be the only thing that has failed, your pictures would still come out properly. If those images are all black it is possible that you are having issues with the CCD sensor or the lens shutter itself.
Esta resposta foi útil?
Pontuação 3
3 comentários:
Thank you, oldturkey03. I will do this and report back. ☺
por
Nikon contacted me and did some over the phone trouble shooting. Not screen it is the sensor. I am going to give it to them for evaluation. Not sure what I will put into a repair this is a camera that has hardly been used ~ 125 pictures taken total. I want to say we paid $270 for the camera. It only worked a small time and the ccd sensor went bad. When I look on the internet tiis is a fairly expensive part w/o labor Thanks for your help. Melinda
por
Melinda Rhodes absolutely. The sensor seems the most expensive part (as much as a used camera) even aftermarket it still costs a small fortune. Sorry about that.
por
I have a similar issue with a Nikon Coolpix AW100 - black screen with icons showing. The screen does show menu functions and previous pix/video but not live video or new pix. Flash works too. This happened while taking pics. 3 good ones then boom, black screen. Almost like I hit some strange button combination.
The camera has been great before this. Really hoping someone has a fix / hack for this.
Pontuação 0
Adicionar a sua resposta
Melinda Rhodes será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 16
Duração total: 2,723
