Ir para o conteúdo principal
Lançado em 16 de setembro de 2016. Modelo 1660, 1778 Disponível como GSM ou CDMA / 32, 128 ou 256 GB / Ouro Rosa, Dourado, Prateado, Preto Mattte e Preto Brilhoso.
iPhone 7 which is dead
i have an iphone 7 which is dead i tried everything i could but nothing, i measured every single caps on the board but no short and ,also i did connect it to a power supply zero amps , but when tries to boot up it goes up to 0.06 or 0.07 ma and stays there
i was wondering if someone can help ,also i measured voltages from PMIC
all the rails have the right voltages :{
and i tried to make it hot with power supply but as the currents consuming is very low it doesn't produce enough heat
thanks for reading :)
Esta é uma boa pergunta?
Pontuação 2
9 comentários:
did you check tristar
por
Or batt_main?
por
Yes i did replaced the tristar and batt_main is work well as i get normall voltages from pmic
por
is it taking amps on the power supply without the power button being pressed
por
hi ,no it does't
por
Exibir mais 4 comentários
Adicionar um comentário
1 resposta
I also got a problem like that but i solved with by changing U2 ic.Most of the iPhone dead with by using copy charger,
Esta resposta foi útil?
Pontuação 0
1 comentário:
i already tried that
por
Adicionar a sua resposta
yousef será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 11
Ao todo: 315
