Can anyone help me with a 820-00138 logic board?
This Macbook had an accident with water. It had less than a year of use and I bought it to try to fix it. I made important advances. I replaced the battery. I changed the screen. I cleaned the logic board and the machine works. When cleaning the hob I have identified two components that may be in trouble. The macbook displays images only on the hdmi port. I do not have advanced knowledge of computer repairs and I need someone to help me solve the problem.
Attached is a photo with the identification of the suspect components. Where can I buy? Below the link of a video with the defects and in the end detailed photos of the components that I identified
Esta pergunta é pertinente?
@pcsiqueira you definitely have some failed components. Yes those could be causing your issue. Here is the thing so, your video does not help. You need to add some good images showing the components location on the logicboard. You also want to give us the logic board number which will make it easier for anybody trying to assist you with that., or at least identify your computer. You are listing the device as a Macbook Pro but keep on referring to a Macbook. Use this guide to post the images with your question Adding images to an existing question
por oldturkey03
@oldturkey03 Thank you for your attention. I added more information. Identify suspect components. Now I need to find them
por PAULO SIQUEIRA
