Ir para o conteúdo principal
The Samsung Galaxy Note 5 (called the Note5) is a phablet-style phone with stylus, manufactured by Samsung, released in August 2015.
Power button stopped working
I dropped my phone and now the power button doesnt work. But now my phone ran out of battery and there is no way i can turn it back on because the power button stopped working.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
@roberto21 you will have to open it up and take a look at what actually got damaged. Use these guides and teardown Samsung Galaxy Note 5 to actually get into the phone. Your battery should charge regardless of your broken power button.
Esta resposta foi útil?
Pontuação 1
3 comentários:
But i have a [problem. the back of my phone is all cracked. Would i damage it more if i open it up?
por
@roberto21 yes you would. Plan on replacing this as well. Sounds like your phone has gone through some rough times ;-)
por
Take off the back of your phone and where the power buttons at remove the plastic button and actually see what is is pressing and use your finger to turn on
Pontuação 1
Adicionar a sua resposta
Roberto Cedillo será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Ao todo: 3,503
