Ir para o conteúdo principal
Modern rebirth of John Cooper's classic automobile, made by BMW.
14 Perguntas Visualizar todos
heating issue mini cooper 2005
even, fan, thermostat are correctly operating and coolant liquid is fool, the temperature is high.
could you, comment about the common problems and the respectly solutions for this issue,
thanks a lot.
Juan José Blas
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Hi Juan, if the thermostat is operating normally then there could be air stuck in the system which is what's causing the overheating. I would have the system bled.
Esta resposta foi útil?
Pontuação 1
Juan Blas make sure that your radiator is not obstructed by anything, that your fans come on appropriately. After that you'd possibly be looking at water pump issues.
Pontuação 1
Adicionar a sua resposta
Juan Blas será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 624
