Xiaomi Mi Mix wont power on
My Xiaomi Mi Mix showed low battery sign so I plugged it in to charge. The phone immediately went off. I pressed the power button to restart it, it showed the Xiaomi logo then immediately went off and since then (this was 2 days ago) it has not powered on.
Kindly note the following:
1. It didnt have water spilled on it
2. It didnt fall or have any mechanical damage
The only thing was, the battery was low, I plugged it in to charge and it went off and never came on again. I have used the same charger to charge other phones so I doubt if the charger is the source of the problem.
Kindly help, what is wrong with the phone?
thanks
Esta é uma boa pergunta?
11 comentários
Please help me. Still stuck on this issue
por pystar
I was told on xda that it could be the charger fried some circuits or so. How can I verify if this is true and convert the phone to a paper weight?
por pystar
Please help. Still on this issue
por pystar
Hi @pystar ,
How long have you left the charger connected?
If only for a short while, give it up to at least 4 hours and see if charging has recommenced. Sometimes it takes a little while for the battery to recommence charging especially from a very low charge state.
If the phone does start to recharge allow it to fully charge before attempting to turn on the phone.
por jayeff
@jayeff the only fear I have is that maybe the former charger I used spoilt something inside the phone. I pray and hope not because I dont know why something in the phone could fry just by plugging in a charger I have been using for a while now.
How would I know if that is the case?
por pystar
Exibir mais 6 comentários
