Ir para o conteúdo principal
Smartphone Samsung lançado em janeiro de 2016. Modelo SM-J320
Phone touch screen not responding Samsung J3 [J320n]
after doing a hard reset the touch screen is still unresponsive. also when it was dropped initially about 10 hours ago the left side of the screen had a tiny crack. any ideas on what could be broken? Screen or motherboard?
any help?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Jack Nicolsen you cannot make the determination without working on it. The number one give away on here is this "dropped initially about 10 hours ago" and " the left side of the screen had a tiny crack" You have a failed digitizer. Replacing that will resolve your issue. This video should help you with that. Don't start soldering on the board until you have properly checked everything else.
Esta resposta foi útil?
Pontuação 1
I just cleaned the digitizer port contacts with contact cleaner and it worked.
Pontuação 0
Adicionar a sua resposta
Jack Nicolsen será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 38
Ao todo: 8,229
