Ir para o conteúdo principal
Philip Wake-up Light identified by modelnumber HF3500/60.
How do I disable the speaker/alarm on a Philips 3500 Wake-up Light?
The worst "feature" of this wake-up light is the inability to turn off the alarm and just use the device as a wake-up light. There doesn't seem to be any videos online that provide clear instructions on how to disable the alarm. One forum suggested drilling a hole through the piezo speaker - if you can find it and avoid damaging the circuit board, which I think I might do.
Is there a better way to go about doing this?
Esta é uma boa pergunta?
Pontuação 2
4 comentários
I ended up just stabbing the center hole and the surrounding 6 holes with the iFixIt screwdriver. It popped the piezo speaker and disabled it with minimal work.
por
Kevin Kramer for as long as it worked for you ;-)
por
Kevin you're a genius my good sir :)
Did as you, only had a leather needle handy, but it did the job.
por
I appreciate Kevin Kramer's suggestion since I watched a few videos that didn't explain the 6 hole approach! I futzed about with a paperclip, but what finally really helped me get the leverage I needed to push out the speaker was a regular ol' thumbtack. I *think* I've gotten it out, it's been quiet during the last three tests even though as I watch it I can hear the phantom beeping (my gosh, that's an annoying sound!). Thank you for posting this.
por
Adicionar um comentário
2 respostas
Pergunta mais útil
Kevin Kramer check on here. Royal PITA but possible. Use an old credit card instead of a screw driver to open it up. Unsolder the speaker or develop a turn off circuit ;-)
Esta resposta foi útil?
Pontuação 2
I just used a long needle to poke the speaker through the grill until it didn't work/couldn't make a sound anymore.
Be aware if you do this, that you can't get the sound back unless you replace the speaker unit. I'm not planning to do that though. 😂
Pontuação 0
Adicionar a sua resposta
Kevin Kramer será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 20
Ao todo: 7,354
