Ir para o conteúdo principal
Os modelos para os Estados Unidos foram lançados como veículos do ano modelo 2012. Os primeiros modelos incluem a opção de carroceria sedan de quatro portas ou hatchback de cinco portas, motor 2.0 litros DOHC (148 cv), transmissão manual de cinco marchas ou câmbio Lineartronic CVT com modo manual de seis marchas com paddle shifting.
Key will not release
2013 Subaru Impreza
Key will not release when we shut the engine off. We have already troubleshot several steps. Brake is applied, transmission firmly in park, pushing key inward while turning engine off. Engine shuts off but will not complete cycle so that it can be removed.
Esta é uma boa pergunta?
Pontuação 2
1 comentário
Hi don, is the steering wheel locked? Make sure that is can turn a full 360.
por Compartilhar
Adicionar um comentário
3 respostas
Pergunta mais útil
I had this issue with my 2016 Impreza. After pulling apart the center console, I figured out what was causing my issue.
To move the shift knob the driver needs to squeeze in the button on the front (blue circle in the picture). This lifts up a rod through the knob (red line in picture) . with the rod up the shift knob can be moved into gear. The rod also presses a button when in park, releasing the key. My issues was the rod was not dropping all the way down and activating the switch. I pulled the rod out and put some light grease on it, hasn’t been a problem since. It was not to much work to get the rod out but I don’t remember exactly how.
Imagem
Sorry its so late, maybe this will help someone else
Esta resposta foi útil?
Pontuação 2
If it has a locking steering column, the wheel may be turned too far. Turn the key while jerking the steering wheel back and forth fractionally.
Pontuação 0
Included with the above recommendations, I depress the brake pedal while removing the key. This might help.
Pontuação 0
Adicionar a sua resposta
don fagan será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 46
Ao todo: 6,995
