The backlight is not working.
My phone just turned off and then when I turned it on it doesn't lit anymore
Esta é uma boa pergunta?
@ameliadepp could be the backlight in your display or the backlight driver as well. I would start with a new display assembly. Use this guide Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement for that, If nothing else it will be your known-good point for further troubleshooting. Use these as your guide for further troubleshooting if it should be necessary
Esta resposta foi útil?
Vertical irradiation the screen with a strong light, if you can see the pictrue, the back light is bad and you need to repalce a new LCD screen. If you cann't anything, the display may broken.
Últimas 24 horas: 3
Últimos 7 dias: 5
Últimos 30 dias: 10
Ao todo: 3,072
