Ir para o conteúdo principal
Repair information for the Gaggia Classic Espresso Machine. Can also be helpful for repairing a Philips or Saeco espresso machine.
20 Perguntas Visualizar todos
Not enough water pressure to force through the pod
Unit comes on, when ready to force water through the pod, the unit sounds like it goes to half power. Made sure pod isn’t too tightly packed. Regularly descale the machine, hoses are clear, unit is primed, just very little water pressure. What is the issue?
Esta é uma boa pergunta?
Pontuação 1
1 comentário
Me too! Wish I had a guy near by to fix this.
por
Adicionar um comentário
2 respostas
Solução escolhida
Why don't we see if this solves your problem
https://m.youtube.com/watch?v=Ghti27dMZb...
Esta resposta foi útil?
Pontuação 3
2 comentários:
@oldturkey03 thanks. I had good teachers!
por
Pergunta mais útil
@shammond86 you definitely want to check all parts for obstructions caused by debris or buildup. If all that looks good and is clean you need to consider bad hoses or a pumps issue.
shows a typical water circuit for the Gaggia
Pontuação 4
Adicionar a sua resposta
Susan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 12
Duração total: 6,182
