How can I repair charger
How can I repair the charging female part on the Blu vivio 5r?
Esta é uma boa pergunta?
@bedanngugi difficulty with your off-brand phone is finding instructions on how to tear it down,.the charging port is soldered to a separate sub-board.
You would have to desolder it and replace it or replace subboard WBL7519 completely. The port is available at places like this
Esta resposta foi útil?
Ok when considering upgrading to a new phone which phones are built well but are also easy to repair
where can I buy this piece?
mario lopez do a search for the subboard WBL7519
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 1,028
3 comentários
What specifically is wrong with it? Not charging? Visibly broken and needs a new port?
por Rachel Acosta
The charging port is moving and has to be in a slightly upward angle for the changing to take place so I was wondering what I can do to fix the issue
por Bedan Ngugi
You need to fix the charging port or replace a new one. It needs a solder so you'd better send it to a repair shop.
por Mandy
