How do I replace the LCD Cable
How can I replace the LCD Cable on the Toshiba C75D. I don't know how to disengage it from the motherboard. I don't know if it is soldered or not.
Esta é uma boa pergunta?
It looks like it's a cable as in Step 10 here: Substituição da tela LCD do IBM ThinkPad X41
or in Step 12 here: Substituição do cabo do LCD do Asus Laptop K75VM
This one's actually a Toshiba, if it makes you feel better. Step 7, middle picture: Desmontagem analítica do Toshiba Satellite A215
Basically, it's likely not soldered down but do be careful when unplugging it. The pictures above should give some idea of how to do it, but I'd also say to throw in some patience.
You got this!
Guia
Nível de dificuldade:
Moderado
Guia
Moderado
30 minutes - 1 hour
Guia
Moderado
25 minutes - 1 hour
Esta resposta foi útil?
Thank you so much for your answer. I can't see how to unplug it....whether it is pulled straight up....slid to the side, etc. Is there a video somewhere that actually shows how to remove it?
@marie540 Here's a video of someone removing an LCD cable from a Dell laptop (skips to the important part): https://www.youtube.com/watch?v=1_99jpJe....
And here's a video of someone replacing an LCD cable in a Toshiba (skips a fair bit, but it's a long and slow-paced video): https://www.youtube.com/watch?v=FzB4S6hq...
At about 15:32, he says that the cable eventually failed, and opens it up, if you're interested in that. You can see that the wires are frayed and broken, and he recommends opening and closing the laptop as little as possible to reduce the strain on the wires in the hinge.
Hope this helps!
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Ao todo: 1,969
