Ir para o conteúdo principal
O Samsung Galaxy A5 (2016) é um smartphone Android lançado pela Samsung Electronics em 2016.
water damage, touchscreen issues
so i may have dropped my phone down the toilet for maybe 10 seconds
at first it started flickering green but after a night it dried out and the screen worked fine, sound works perfectly, it charges perfectly.
only issue is the touch screen, one second itl work fine, next minute it either freezes and i cant press anything, and i press the power button and turn it back on and itl work for anywhere between 10 seconds to a few minutes or so.
or buttons i havent even touched will be pressed, like if im typing it might press other letters, or searching in google it might zoom in and out etc. also the drop down menu with wifi, mobile date, bluetooth etc. will keep dropping even when im nowhere near it.
will these issues go away overtime or will i need to get a screen repair or something???
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Okay, I had this same problem with my 3DS, but I know what's going on. There is water inside of your screen and it's messing with the touch sensors that are in the screen. (The touch sensors help feel your tap on the screen). I advise you take it to a repair shop, but if it can't be fixed, try getting a new phone.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Callum M será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 17
Ao todo: 1,020
