New battery still draining
Hi,
I put a new battery in a galaxy S7 as it was using a full charge in 6-8 hours.
Put the new battery in charged it all last night and in 4 hours it's drained 40-50%.
Any ideas what I can do?
Esta é uma boa pergunta?
Hi,
Hi @jaymie1989 ,
Do you have GPS, WiFi enabled?
If not necessary disable them in settings as they are a big drain on power.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 148
3 comentários
This sounds like a settings issue not a hardware issue.
por oldturkey03
6-8 hours is pretty good. You sure it’s not normal
por Aiden
I would definitely try backing the phone up first then doing a factory reset to see if it fixes the issue.
Note that battery drain can be caused by certain installed apps too.
por Ben
