Ir para o conteúdo principal
O tablet emblemático da Samsung, lançado em março de 2017. Identificado pelo número de modelo SM-T820.
Google play store not responding
Hi my google play store is not responding anytime i click on the icon it freezes the phone and after some seconds it says unfortunately,google play has stopped
need help.
Esta é uma boa pergunta?
Pontuação 4
Adicionar um comentário
4 respostas
Pergunta mais útil
Go To Settings --> Applications
- find Google services, select Force Stop, and then clear data
- find Google Play store, select Force Stop, and then clear data, and then uninstall updates if there are any
- restart the phone
Esta resposta foi útil?
Pontuação 3
My tablet has bin doing the same thing but mine did Google play freeze thing after it firmament it's self I fixed my tablet now Google play dose this freeze thing so I do not have no games at all on my tablet.
Pontuação 0
Samsung J3 2017 here. I solved this problem of having the repeat small window appear stating: “Google Play Store Has Stopped” Close App.
I went into Setting -- Apps. From here I opted to have the Apps Listed. I selected Google Play Store and clicked on, Force Stop. I was given the option to reset Google Play Store to basic, beginnings, function ability. This I did. From here the annoying repeat window (above) disappeared. I then updated all my apps. Regards. U.K.
Pontuação 0
1 comentário:
Hi Robert, I have the same ph as you and my google play store has completely disappeared (not disabled). Also my google play services don't appear to be working properly as everytime I try and access anything google related I get an error message saying that it wont run without google play services which are not supported by my device or my device is not compatible. In settings>apps it shows google play services as installed and enabled. I have the latest software update and 1gb of space so run out of ideas.
Do you have any ideas or suggestions ? Thanks
por Compartilhar
Why Google stop working on my tabletk keep saying no response
Pontuação 0
Adicionar a sua resposta
layna será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 26
Ao todo: 4,674
