Ir para o conteúdo principal
The HTC Vive is HTC's first virtual reality headset, co-developed with Valve and released in April 2016. The device's model number is NM80PJT100.
How do you remove the screen from the lens cases?
I am trying to remove the screens, but can’t seem to get them off. I have already removed the screws from the screens, but the screens don’t seem willing to detach. Does anyone have advice for removing them? Thanks.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
After removing screws from the screens, you can use an iFixit opening pick to safely detach the screens from the lens case. There is a groove along the screens and opposite from the lenses that you can pry open using the pick. There will be some resistance, but they will eventually come loose. There are additional instructions on how to open the screen in the Screen Removal Guide.
Imagem de Thin prying tool for opening electronic devices. Opening picks are essential to open any iPad, tablet, or smartphone sealed with adhesive.
Produto
iFixit Opening Picks (Set of 6)
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Caleb Watts será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 183
