Ir para o conteúdo principal
O BlackBerry Priv é o primeiro smartphone da fabricante canadense a rodar o sistema operacional Android, combinando segurança e bom desempenho.
hard reset? recovery mode?
i have a customer whos father passed away. she is trying to reset his blackberry to sell it as she cannot get into it. i cant seem to find a way to hard reset via button combo. help?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Imagem
I found this after seeing your question. I hope it helps. I posted the image because I had to jump through a hoop to see the answer.
Here is the website it comes from: Three ways to Hard reset Blackberry Priv.
Esta resposta foi útil?
Pontuação 0
2 comentários:
I will try this when I get to work! Thank you! :)
por
Np! I hope it works!
por
Just log in 10 times with the wrong password or wrong pattern etc., then the phone will delete everything down to factory reset level, and restarts from scratch again.
Pontuação 0
1 comentário:
Actually that is incorrect, it will leave it stuck in a mode where you need the original google account to load past the setup screen... It has to be done via the actual factory reset option to avoid this...
por
Adicionar a sua resposta
Austin Harris será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 26
Ao todo: 11,277
