Ir para o conteúdo principal
Which capacitors are needed to be replaced
I understand the capacitors to my TV need replace due to the fact the TV is powering on and off on its own; however when I had to replace the capacitors on my other TV I was able to search online and order a completed pack of the capacitors need to completed the job. From my understanding the capacitors used by Samsung are inferior to the ones that the manufacturer should have installed. Is anyone able to assist me in determining which capcitors need to be replaced with a higher valued one and which ones are needed? I am asking this question for several reasons one being that I do not want to breakdown my TV until I have to actually do the work.
Model Code: UN55ES8000FXZA
Version No: TS01
AC110-120v 60Hz 160W
Typical power: 82W
Thank you,
Bill
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
William you are going out on a hunch here. You are assuming it is your caps that need to be replaced. I am not convinced of that until you measure the caps as well as other issues with the power board. If anything I'd suggest that you purchase a repair kit for your power board like this one. Those kits are developed based on common errors, which may be a better choice. Still a guess, but at least an educated one. Even with this kit, I would still suggest you check your board first.
Esta resposta foi útil?
Pontuação 3
1 comentário:
Thank you I will give that a try.
por
Adicionar a sua resposta
William será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 5
Duração total: 370
