Ir para o conteúdo principal
What is a good inexpensive Ram Tester
we work with 8500s, 10600s, and 12800s 204 pin ram pieces, and we're looking for a good testing unit that can test 1 piece at a time to see if it's working, and also to help identify mis-labeled pieces of ram or unlabeled pieces of ram.
i found a few units for around $3500, but we're not looking to spend that kind of money as we don't have that much mis-labeled untested ram. does anyone know a reliable inexpensive unit that would work well for this?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
Have you considered using an old laptop with MemTest86? That's what I use to test ram, and it's a cheap option. I just have one plugged into an external monitor and I keep the rear panel permanently removed.
- Jasen
Esta resposta foi útil?
Pontuação 2
1 comentário:
thanks.... i'll look into that
por
Adicionar a sua resposta
dollartripclub será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 69
