Ir para o conteúdo principal
Model A1347. Released on October 23, 2012. Core i5 or Core i7 Processor. Apple Fusion Drive.
SSD not beeing recognized
Hi
I have just installed a Samsung 850 EVO 250 GB ssd in my Mac Mini (late 2012).
I have created a boot disk on an external Toshiba USB HD.
When I boot the USB HD to install the newest OS Sierra, I cannot see my drive anywhere.
I have checked the cables 10 times and all is a fit. Any ideas?
Update (10/02/2017)
Thank you for your reply.
I am replaceing the internal 5200 RPM HD with the SSD.
Once I put the original drive back in - everything works (it boots the drive).
The external HD with the install partion on it is - unfortunately - just an external HD with not possibility to swap the disks out.
Is there a way of testing if the SSD is faulty? Could it be an issue that I boot from an external HD rather than USB? Could it be that I need to update the firmware?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Are you replacing the HD drive or adding it as a second drive?
por
Adicionar um comentário
2 respostas
Solução escolhida
You have a few options here:
Put the SSD back in with your system connected to the internet (ideally via the Ethernet cable connection) lets see if we can get the internet recovery to run. When you boot up press and hold the Option-Command-R or Shift-Option-Command-R keys you should see a globe icon on your screen. Let the system run it may take some time! Depending on your link it could take a good hour to get to the install screen.
The other approach is to create an OS installer thumb drive following this guide. Here we need to have the system running with the old drive so you can prep the thumb drive. Follow this guide: How to create a bootable macOS Sierra installer drive. Then put the SSD back in and then boot up with the installer drive.
If you get this: Startech 2.5" SATA to USB adapter it will allow you to hook up your SSD (or your HD) externally so you can leverage it for the OS installer and also migrate your files over.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thank you for your answers.
I bought a SATA to USB adapter and formatted the drive, reinstalled it - and it worked like a charm. Thank you.
por
Pergunta mais útil
What you have done should work. Try it this way. Put the original HD back in there machine. Put the Samsung in the external case. Boot from the internal and use Disk Utilities to format GUID & MacOSX extended and install 10.12 first. Now see if will take High Sierra.
Pontuação 3
Adicionar a sua resposta
Christian Madsen será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 20
Ao todo: 5,117
