Ir para o conteúdo principal
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
Don't know if screen broken or something else...
Hello,
I dropped my iphone 3s once and no more images appears in the screen.
Some time later I put it to charge and screen light went on, but it shows only some kind of pixel pattern in grey, with vertical white tin lines.
At this stage I cannot tell what is wrong. Screen seems not cracked, since backlight went on but nothing seems physically broken.
The only thing I can do is to press both buttons at the same time and screen goes black like it turn off. When I turn it on again, I get some weird horizontal lines showing on and off for some seconds, then some color randomly placed lines and then a nice white screen for some seconds before the weird horizontal lines dance begins again, like and old tv with a bad antenna.
I will like to have an opinion in this, in order to know what can I do with it since I hate to trow away stuff that can be fixed.
I took off the screen a little bit and the connector #1, and the screen goes black and you must 'turn on' the phone again. that connector is a little devil, who will umplug itself very easily. But with the connector right on place the problem is the one described.
The others connectors, I didn't remove. They seem well placed.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
coursparis this "some kind of pixel pattern in grey, with vertical white tin lines" is pretty indicative of a broken display. Here are the guides iPhone 3G needed for the repair. To find a replacement display will not be easy or cheap.
Esta resposta foi útil?
Pontuação 2
4 comentários:
with grey I don't mean lcd liquid, just a degree of very light grey in a perfect pattern. Sometimes is not exactly grey but light blue...
por
coursparis add an image of what your screen displays with your question. Use this guide Adicionar imagens a uma pergunta já existente for that. It will allow us to see what you see.
por
done! thanks!
por
I would advise you to repair phone in a workshop or find the skilled person on this website
por
Nobody? please......
Pontuação 0
Adicionar a sua resposta
coursparis será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 217
