The HP Officejet 6600 Inkjet Multifunction Printer is a 4-in-1 device that can print, scan, copy and fax.
darlenebarber54 @darlenebarber54
Rep: 1
Postado: 26 de set de 2017
will not print from computer
Esta é uma boa pergunta?
5 comentários:
Hi,
Has it worked OK before when connected to the computer?
Does it work OK if you try to copy or scan a document using the printer's control panel?
If it works when using the printer's control panel, what make and model of computer is it connected to and what OS is installed in the computer?
26 de set de 2017 por jayeff
Printerhead? what do you mean? or are you trying only to print from your pc?
26 de set de 2017 por jbermudez27
Yes. It is not printing from computer or copy or fax
17 de jan de 2018 por lorenzo.walker
Hello jayeff,
It is not printing from computer, or fax, or copy. I have replaced all ink cartridges in printer
Hi lorenzo.walker,
Have you tried a 'Clean Printhead"operation from either the printer's control panel or the HP printer software in the computer?
On the printer press the Right Arrow > Setup > Tools > Clean Printhead.
Do it 2-4 times to see if it starts to print.
17 de jan de 2018 por jayeff
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 61
Hi,
por jayeff
por jbermudez27
por lorenzo.walker
Hello jayeff,
por lorenzo.walker
Hi lorenzo.walker,
por jayeff
