Ir para o conteúdo principal
Lançado em 22 de setembro de 2017. Modelos A1864, A1897. Disponível nas versões GSM ou CDMA, opções de armazenamento de 64 ou 256 GB, e as opções de cores são dourado, prateado e cinza-espacial.
iPhone 8+ and iPhone 7+ lcd
iPhone 8+ display compatibility and iPhone 7+?in Ches the difference
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
6 respostas
Pergunta mais útil
Here's the latest info on the iPhone 8:
Desmontagem do iPhone 8
Esta resposta foi útil?
Pontuação 3
Both of them can't work well on each other. I write an article "What’s the difference between iPhone 8 and iPhone 7 LCD screen?", if you want to see it please see my profile then visit my blog. Also you can watch the video here:https://youtu.be/KxFovnbcY3E
Pontuação 1
Be VERY AWARE of chinese sellers on eBay trying to pass off iPhone 7 Plus screens for iPhone 8 Plus. They nearly look identical.
Pontuação 1
1 comentário:
7 has hooks at the top and 8 has metal brackets
por
They looks similar but they can't work well on each other or say it not full functioning on each other,
Pontuação 1
No, you wouldn't be able to interchange displays between generations of iPhones. The 8 uses a 3 channel, temperature sensitive light sensor.
The 7 uses a single channel, light only sensitive sensor.
The ribbon cables are also likely different.
Pontuação 0
Yes you can put the iPhone 8 + digitizer on a 7+ iPhone.
And it will work just fine, only the display.
You need to use the orignal homebutton and sensor/frontcam cable.
The screws in the bottom wont fit unfortuanately
Pontuação 0
1 comentário:
It can work but will have issues
por
Adicionar a sua resposta
Alex Pro será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 15
Ao todo: 5,392
