Ir para o conteúdo principal
The Dell Latitude 7350 hybrid laptop (model number: Latitude 7350) is a 2-in-1 device that functions as both a laptop and tablet. Released in 2015, the Latitude 7350 is no longer being produced. You can find repair guides and device information here.
7 Perguntas Visualizar todos
My touchscreen completly stop work after load wrong firmware
Hi,
I have the same issue in Dell 7350. After replace touchscreen my x-axis was inverse. So i run reflash from this topic, and now my touchscreen completly stop work. Please help me :(
Update (09/24/2017)
From the beginning. My post was moved from this topic:
Dell Venue 8 Pro inverted x-axis touchscreen?
I read about, problems after replace touchscreen. I have the same problem, x-axis was inverted.
I was stupid, because i run the script from link above. Of course this is firmware for dell venue 8, and of course it can not work correct with my hardware. My touchscreen now completly stop work.
I guess, if someone find firmware for dell venue 8, maybe someone have also firmware, but for dell latitude 7350.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
You may have turned off touch screen in the setting some how, or the wires. connected to the screen might have came off some how. You can go to staples and they should be able to fix it for you or you can call the company and they could tell you how to fix it.
Esta resposta foi útil?
Pontuação 0
Did you ever think about if your screen is dirty? That could be the reason, because touchscreen does not work for me when it is dirty. Maybe you use it too much, and it has too many finger prints. This question is vague, so i do not know if you did this or not, but if you didn't then wipe your screen with a special towel meant for wiping touch screens. If that doesn't work, then go to a store to get if fixed. Personally, I think Dell devices are never worth buying because there is always something wrong with them, and i would replace it, but if you really love that tablet then bring it to a store to see if it can be fixed.
Pontuação 0
Adicionar a sua resposta
Dabidi será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 7
Ao todo: 282
