Ir para o conteúdo principal
White spots on LCD
hello guys,
i have my laptop for a year now but i have some bright white pressure marks from use and people touching my screen is there a way to get rid of those marks otherwise i have to replace my screen
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
@silentmountain no there really isn't. you can try and remove the LCD and disassemble it. Check the diffuser sheets for pressure marks and replace those if necessary. As you can see it sounds like a difficult task, and it most commonly is. If you are really up for it post plenty of images of hat you as you disassemble it so we can guide you step by step. Use this guide Adicionar imagens a uma pergunta já existente for that. Also, attach an image of what your screen currently displays. That way we can see what you see. Otherwise it will work better if you replace it. This video should be of help to you for that task.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
pascal molenberg será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 1,435
