Pular para o conteúdo principal
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1473 Perguntas Ver todas
Why my MacBook doesn't detect MagSafe charger?
Hi,
i have a problem with my black 13" MacBook. Sometimes MacBook didn't detect MagSafe charger. I say didn't because it doesn't charge my MacBook now.
When i connected adapter to my laptop green led doesn't bright. Other times it charged, but now it can't. With the battery it works perfectly, but i don't have other MacBook to charge battery in it.
I try with other charger without results. I think it could be DC-IN or Logic Board. I try DC-IN with a multimeter, and pins one and five are connected, second and fourth also and the center pin it's not connected to other pins. Without battery laptop doesn't power-on, because charger isn't detected.
I would be very gratefully about any help.
Thanks
Regards
Respondido! View the answer Também tenho esse problema
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
kits de reparo de baterias de iPhone
Only $29.99
Buy Now
Only $29.99
Buy Now
1 Solução
Solução escolhida
Pins 1 and 5 are grounds. Here's the pin out: http://en.wikipedia.org/wiki/MagSafe
Check the AC adapter to see if the pins are extending and if they are charged. If it's OK then I would replace the MagSafe port. Here's how to do that: MacBook Core 2 Duo Magsafe Board Replacement
Esta resposta foi útil?
Pontuação 2
Comentários:
Thanks for your response. I'm pending to receive a DC-In board, when i tried it i post if it solve my problem.
Regards
por
Solved. I changed the DC-In board and Macbook charges perfectly.
por
Glad I could be of assistance.
por
Adicionar a sua resposta
josuku será eternamente grato(a).
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Todo: 4,502
