Ir para o conteúdo principal
Repair and support for the third generation of the Flip portable speaker by JBL.
20 Perguntas Visualizar todos
Little part fell off the JBL flip 3 motherboard labeled 1R5
I dropped my JBL flip 3 speaker the other day and I started to hear a rattle inside so I decided to take it apart and see what it was and it was a small box at the top Corner of the motherboard labeled 1R5 and i don't know how to put it back on
Esta é uma boa pergunta?
Pontuação 2
2 comentários:
Exact same problem has happened to me, does anyone have a solution
por
the same excact thing happened to me
por
Adicionar um comentário
3 respostas
@mtz13 without actually seeing what is going on, it is difficult to answer. Consider posting some picture of your board with your question. Use this guide Adicionar imagens a uma pergunta já existente for that. The 1R5 sounds like a fixed 1.5uH inductor. Again without seeing it, this is only an assumption. Those are usually soldered to the board and there is not other way reattach it.
Esta resposta foi útil?
Pontuação 0
Something similar happened to me. The 1R5 piece didn't break down fully and now one contact is lose. I think the only way is to solder it down. https://imgur.com/a/2y4Xy
Pontuação 0
I had the same problem and solved it by cutting a wine cork in size to press the 1R5 piece against the contact. Good luck
Pontuação 0
Adicionar a sua resposta
Joe será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 1,545
