Which kind of MXM slot does it have?
Hello ,
I want to buy the iMac 27" 5k 2017 release and I need to know which MXM slot does it use and if I can use the Mobile GTX 1080 in my notebook in it or not.
I will be switching the cards , becuase an 1080 GTX inside my iMac is more important than inside the notebook.
I will put Apple RX580 inside my notebook if they use the same MXM slot. I assume they should be because it is the same time and same MXM slot generation.
Can you help ?
Here is what I want to do:
- Open my notebook and remove the GTX 1080 card in it.
- Open the iMac I am going to buy and remove the RX580 Pro in it.
- Install the 1080 GTX in the iMac.
- Install the RX580 Pro in the notebook.
I assume they both use the same power (150-180 watts) and produce the same heat. so the cooling will work on both.
Esta é uma boa pergunta?
