Is my sd card slot broken?
Says can't use this memory card. Menu skips right over format card option.
Says there is a card in when there isn't.
Esta é uma boa pergunta?
@jsd9086 it is possible that the card reader thinks a card is inserted due to a bend or stuck switch. Your reader will have one tab that gets moved away when you insert a new card and thus recognizes that. If that tab is no longer working properly, your camera will be told that a card is inserted. Of course, you also should try a different memory card. Use these guides to work on your camera
Esta resposta foi útil?
Thank you oldturkey03
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 6
Duração total: 126
