does the A1052 support 1Tb hard drive
Does the A1052 support support 1Tb drive?
Esta é uma boa pergunta?
Here's how to do it but it uses and ATA drive not an SATA and I don't know where you can find such a drive. It will however, that the 12 mm thick drive.
Search for a ATA100 (IDE) 5400RPM Hard Drive or better
Here's a PDF on doing it:
http://web.archive.org/web/2007011803443...
here's the standard guide: PowerBook G4 Aluminum 17" 1-1.67 GHz Hard Drive Replacement
Esta resposta foi útil?
Will the A1052 support an external SATA drive that I can use as a startup drive?
Sure if the connection is a USB to SATA.
Pre-Installed MacOS: X 10.2.7 Maximum MacOS: X 10.5.8
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 83
