Ir para o conteúdo principal
Bose's consumer range of active noise-cancelling headphones are called "QuietComfort".
21 Perguntas Visualizar todos
Source for procuring quality replacement speaker for QC25
I have the same problem as described here: How toReplace broken speaker for QC25.
In short, the speaker on my right died.
The question is where to buy the replacement part. It seems that this part is available on eBay for a range of prices, which warns me for cheap replacement parts.
I am looking for a source for a quality replacement part, in order not force me to replace (=downgrade) the other, currently working side at the same time.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
@asdmin the only way to get the guaranteed right working speaker is through Bose itself. Contact them and see how much the repair would be. Anything else you'll take a chance but you may just get a good replacement. You can also purchase a complete set that is broke, other than the speaker, and then harvest the speaker from that.
Esta resposta foi útil?
Pontuação 1
2 comentários:
Thanks, the suggestion for a broken unit was very helpful!
por
Before I blew the headphone up, I called Bose. They will replace mine, as it was affected by a manufacturing defect. Nevertheless your answer is correct and valuable. Now given, that this headphone is serviceable, I'll also look for a broken one for parts. Thanks!
por
Adicionar a sua resposta
Daniel Vasarhelyi será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 4
Últimos 30 dias: 6
Duração total: 1,602
