Ir para o conteúdo principal
Phone doesn't turn on, shows apple icon
Hi,
Got a iPhone 6 and it was working, I just had to reinstall new firmware. The battery went dead and never been able to turn it on since, I've replaced the battery with one I know works as I've swapped them with another iPhone 6 and the battery from this non working one works on there and 3utools shows it's a good battery.
However I when I try and turn it on all I get is the apple logo then it goes off. I've left it to charge and I've plugged it into the usb and done the power button and home button and it still only shows the apple logo.
I need help.
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Try a minimum system configuration, leaving only the necessary hardware.
It's unlikely but something might be tripping the phone out.
As I say unlikely but worth a go.
por
Tried that and still doesn't do anything.
Thanks though
por
Adicionar um comentário
3 respostas
Solução escolhida
Hi Jaymie. Looking at the previous answers and your follow-up comments, you clearly have a logic board issue. This will require some micro-soldering rework and is not a DIY fix unless you have access to the right tools, schematics and skills/ experience.
Look locally for a reputable shop that does micro-soldering repairs. Ideally, you want to find someone local but good workmanship trumps locality. If you can't find one locally, then consider mail-in repair. There are several reputable micro-solderers patrolling this forum.
Esta resposta foi útil?
Pontuação 1
Press the home button and the power button and hold for five or 10 seconds and release it should go to recovery mode.
You may also want to try reseating the battery to make sure it has a good connection.
Abbot
Pontuação 0
1 comentário:
Unfortunately didn't do anything.
por
You may need to restore your iPhone on 3uTools.
Please refer this tutorial: http://www.3u.com/tutorial/articles/1857...
Pontuação 0
2 comentários:
I can't use 3uTools as the phone doesn't stay on long enough.
por
What do you mean you can not use 3uTools?
por
Adicionar a sua resposta
Jaymie será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 112
