Ir para o conteúdo principal
What needs to be done for a solder pad missing on the touch connector
I had a iPad mini A1432 come in with missing pins of the fpc (i think it's called) and a solder pad missing as well what needs to be done to fix this ?
It's number 6 I think not sure how to add a photo??
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
is it the top or bottom of the fpc and number of pins in from which side
Esta resposta foi útil?
Pontuação 2
3 comentários:
It's bottom and the third from the right
Maybe a jumper would work?
por
that would be top 3rd from left, which is a ground pin, thats why i couldnt find anything since you said bottom row 3rd from right
por
using pads and the files i have i cant see anywhere that a jumper could go to, possibly some1 with zxw could find something
por
Adicionar a sua resposta
Amika Valentine será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 95
