How to replace inside screen
My inside screen is cracked on one side and I can't use that side for anything don't know how to fix it
Esta é uma boa pergunta?
@mrswelch09 not sure what you refer to as your inside screen. If the image still display properly and complete then you are most likely referring to your touchscreen. If your image does not display properly then it is your LCD. This video should help you with the repair.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Ao todo: 81
