Ir para o conteúdo principal
O OontZ Angle 3 é um alto-falante leve de alta qualidade fabricado pela Cambridge SoundWorks.
Is my USB port damaged?
Please help. My Angle 3 has a damaged USB. I can't charge it anymore because it's destroyed due to incorrect proper plug in socket when i try to charge it. Can I fix this?
Esta é uma boa pergunta?
Pontuação 6
1 comentário
I have this very same issue too with the OontZ Angle 3 Ultra - my USB Port is damaged. Please if there are any updates let me know.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
HI:
Micro USB replacement is possible. You have to have the correct soldering iron and hot air to do it. Take it to a repair shop and ask for a quote. The speaker its self is easy to take apart.
Oh yes I have done it but many years of soldering behind me. No I do not recommend the average DYI.
Also the complete replacement is available for the motherboard.
Good luck
AB
Esta resposta foi útil?
Pontuação 3
1 comentário:
Repair shops want $75 just to turn on their soldering gun!
por
Adicionar a sua resposta
Reader Looker será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 16
Ao todo: 1,931
