Ir para o conteúdo principal
Lançado em junho de 2012, modelo A1278. Processador Intel com Turbo Boost, até 512 MB DDR5 de RAM vídeo
1624 Perguntas Visualizar todos
Updating my 13" 2.9 GHz MacBook Pro with an SSD
I have a 13" MacBook Pro 2.9 GHz i7 (Build 13F1911) that I want to install a SSD drive to make it faster.
Is it worth the upgrade and if so, is there a installation tutorial for it?
Update (09/04/2017)
I do have the 15" though... is it the same procedure?
Esta é uma boa pergunta?
Pontuação 0
8 comentários
The build number is the MacOS version the system is using.
por
Big difference :-}
por
Of course it is. You might want to change your question so that we can put in the correct machine.
por
Let's do this can you take a screen shot of the About Ths Mac window which shows the systems specs.
I don't remember Apple ever offering a 2.9 GHz 15" non retina system. The best we have are 2.6 GHz. I vaguely remember they had talked about it but I don't think it was ever sold. Here's the specsheet from Apple: 15" MacBook Pro 2012
As to the procedure it's basically the same but a different cable if you have the non retina model. The retina models don't offer HDD's they only have blade type of SSD (custom Apple part)
por
Exibir mais 3 comentários
Adicionar um comentário
1 resposta
Solução escolhida
Yes a SSD will make your system smoke! Here is the IFIXIT guide to replace your current HD for a Different drive in this case a SSD: MacBook Pro 13" Unibody Mid 2012 Hard Drive Replacement
I do recommend you also replace the HD drive cable at the same time as they tend to wear. Here is the IFIXIT guide for that: MacBook Pro 13" Unibody Mid 2012 Hard Drive Cable Replacement and here is the part you'll need: MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable.
Imagem de MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable
Produto
$34.99
Imagem de MacBook Pro 13" Unibody Mid 2012 Hard Drive
Guia
Nível de dificuldade:
Moderada
30 - 45 minutes
Imagem de MacBook Pro 13" Unibody Mid 2012 Hard Drive Cable
Guia
Fácil
10 - 25 minutes
Esta resposta foi útil?
Pontuação 2
10 comentários:
As to which drive I would recommend getting a Samsung or SanDisk drive. You'll likely want one that is large enough to hold your work you currently have on your HDD but you'll want one that is still larger for new stuff and still enough extra for the OS to use 1/4 more.
por
Thanks Dan, let me also ask... after i place the SSD how do i install the OSX of my choice? I already do have the OSX installation files provided from the AppStore!
por
There are a few different ways you can do it. The easiest is to get a SATA to USB adapter to plug your old drive into then you boot up using it. Using the OS installer install the OS and all of the OS updates. Afterwards launch the Migration Assistant app. I prefer doing it this way then launching it at the end when the installer asks if you want to copy over your stuff.
If you want to you can also leverage the internet recovery service, or your f you have already setup a USB thumb drive as the OS installer. As this is a fresh drive you won't have access to the hidden recovery partition yet. Once the The drive is prepped properly you'll have it next time.
por
I only have a USB thumb drive available and the 6GB El Capitan installer file. Can i do something with those two?
por
Is it setup to be a bootable installer? If it was that will work. In that case you'll want to use a new user account (different name) that what your current drive has so later you can migrate it over. do make sure you have 8 GB's or more of RAM in the system.
por
Exibir mais 5 comentários
Adicionar a sua resposta
genik será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 324
