Ir para o conteúdo principal
Este dispositivo LG com Android foi lançado em outubro de 2015. O número do modelo do dispositivo usado para criar estes guias é LG-VS990.
My phone has a bootloop problem
My phone has a bootloop problem and i tried to repair myself. The repiar was successfull but after two of working, the issue started again.. so i repaired it agian and aftr the cleaning the dust inside my phone, i small chip was hanging to the motherboard.. Well, I know i f**d up, now i want the original LG Motherboard for LG V10 at&t.. Where can i buy the replacement?
Thanks in advance!
Esta é uma boa pergunta?
Pontuação 2
3 comentários
i checked that before,but i need the original motherboard..not the replicas
por Compartilhar
Fixed wife's V10 after it constantly rebooted. I work for CameraSecurityReviews.com in Indiana as a repair technician servicing audio and video equipment like this http://camerasecurityreviews.com/4-chann... . The root cause of this reboot issue, and sometimes overheat issue found in G4,G5 and V10...is a ball-array mounted IC on the main PCB on the screen side of the board. Its a larger IC without the interference shield over it.
The fix involves heating the IC and PCB with hot air and allowing the solder underneath the re-flow and make a connection again. Don't melt any plastic connectors. Also take out any SD card and the SIM card so they won't melt! Hope this helps someone.
por Compartilhar
I baked my motherboard. Worked like a charm. Using it for more than a daynow with no issues.
por Compartilhar
Adicionar um comentário
1 resposta
Solução escolhida
Hi!
You could try hereor here.
Esta resposta foi útil?
Pontuação 5
3 comentários:
@oscarsp @yvaneck jkingsnorth sorry but no SPAM here. Just a couple of benign links to a replacement board.
por Compartilhar
Thanks for the warning @oldturkey03 , but I vote as not spam. The links help to solve the problem and I know that @alexniculescu is a good assistant does not send spam. I apologize if I made a mistake marking it.
por Compartilhar
@oscarsp it's all good. Not a warning just making sure helpful answers are not being misunderstood :-) No apologies necessary
por Compartilhar
Adicionar a sua resposta
Anche Karthikesh será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 19
Ao todo: 12,615
